[Ry...] Posted July 15 Share Posted July 15 Hello all, reaching out for some assistance with an alignment. Once aligned to the CAD model I need to do a line trace at the top and near the bottom for profile measurements to the CAD. Object parameters: an amorphous perimeter a flat top a hole for locating X and Y 0 Second hole for alignment of the +X axis... I cant get the software to compute the alignment. I am setting first step as top plan, and z=0 at top plane I can set X,Y zero as the center cylinder It does not let me choose the second cylinder to set X+ alignment. I tried making a 3d line between the 2 cylinders, i tried projecting that line to the top plane, and still nothing. Any thoughts on what I am missing? Link to comment Share on other sites More sharing options...
[Da...] Posted July 15 Share Posted July 15 Intersection of second cylinder with top plane should work. Link to comment Share on other sites More sharing options...
[Ma...] Posted July 15 Share Posted July 15 Doing circle on second cylinder should be enough - that's same advice as David mentioned. I think 3D line from cylinders should work too - perhaps you made some mistakes in making it. For that use only Recall - not feature and not points Link to comment Share on other sites More sharing options...
[Ry...] Posted July 15 Author Share Posted July 15 I did the intersect of the second hole with top surface and it worked! Thanks. I knew I had to be close. Link to comment Share on other sites More sharing options...
