Change pallet sequence using PCM
Hello
Is it possible to change the sequence in the autorun pallet using PCM?
I have a pallet with 100 positions,
operator load 55 parts in pallet position 2-56,
the operator selects all used positions manually by clicking but never cares about the sequence, just selects the correct icons.
On the operator account is not possible to turn on a different method of entry (like a loop)
I want to change the sequence to:
2,56,3,4,5,......,55
lower number, highest Number, all other growing
I know how to read actual sequences and sort them as required.
S=chr(34)
First=getRecordHead("firstpalletlocationnumber")
Actual=getRecordHead("palletlocationnumber")
if First==Actual then
Last=getRecordHead("lastpalletlocationnumber")
addToFile("C:\temp\pre.txt","Last="+S+Last+S)
Sequence=getRecordHead("palletlocationnumberselection")
if Sequence=="" then
Sequence="1"
First="1"
Last="1"
endif
//sorting part removed to reduce syntax
i=0
repeat
i=i+1
PalletNo=strElement(i,",",Sequence)
until PalletNo==""
PalletNo=i-1
if PalletNo>2 then
SequenceN=""+PalletNo[1]+","+PalletNo[PalletNo]
for i=2 to PalletNo-1
SequenceN=SequenceN+","+PalletNo
next i
addToFile("C:\temp\pre.txt","SequenceN="+S+SequenceN+S)
endif
endif
But how to send this information to Calypso to run in this sequence?
Many thanks
