[Ke...] Posted April 11, 2024 Share Posted April 11, 2024 What would be my best plan to output both mm and inch? Link to comment https://qualityforum.zeiss.com/topic/5866-both-inch-and-mm-output/ Share on other sites More sharing options...
[Cl...] Posted April 11, 2024 Share Posted April 11, 2024 Please sign in to view this quote. Use a Result Element with formula. Link to comment https://qualityforum.zeiss.com/topic/5866-both-inch-and-mm-output/#findComment-21896 Share on other sites More sharing options...
[Ke...] Posted April 12, 2024 Author Share Posted April 12, 2024 Adding formulas is definitely a good solution but the Delima I have is the print is created in metric and the customer data is reported to the customer print. Our machinists are more comfortable with inch so I was hoping there might be maybe a setting so I can have one piweb report in metric and one in inch. I don't think it exists, but one can wish.. 🧑💻 Link to comment https://qualityforum.zeiss.com/topic/5866-both-inch-and-mm-output/#findComment-21898 Share on other sites More sharing options...
[Cl...] Posted April 12, 2024 Share Posted April 12, 2024 Please sign in to view this quote. Then run the program, report in inch. Switch units to mm and run a subsequent evaluation. Link to comment https://qualityforum.zeiss.com/topic/5866-both-inch-and-mm-output/#findComment-21900 Share on other sites More sharing options...
[Wa...] Posted April 12, 2024 Share Posted April 12, 2024 If you are using PiWeb, you can copy the template that you are using and add it to the "Multiple Report". Open the template in PiWeb Designer and select the element you want to modify. In this case, it is the Nominal Value text box. Select the Properties tab on the left and add whatever calculation is needed Link to comment https://qualityforum.zeiss.com/topic/5866-both-inch-and-mm-output/#findComment-21902 Share on other sites More sharing options...
