[Pa...] Posted April 10, 2024 Share Posted April 10, 2024 Hi, I´m metrologist in a manumacturing company, and we make part for automotive companies. In one of our client´s drawing we see a secondary datum, formed for two holes and both are datum B (B-B). Both have maximum material requirement in Position evaluations of other caractiristics, for example in a Position tolerance of a Plane. You can see in the attached images. My quetion is, how can I do the alignment with the secondary datum knowing the MMC in it. There are some images attached. thankscap 3.JPGcap 2.JPGcap 1.JPG Link to comment https://qualityforum.zeiss.com/topic/5870-maximum-material-condition-in-secondary-datum/ Share on other sites More sharing options...
[Cl...] Posted April 10, 2024 Share Posted April 10, 2024 Each datum -B- has equal value. You would combine the two Datums (Holes) by recalling them into a 3d-line to use for a planar rotation in the alignment. As far are applying the bonus tolerance for those holes, I don't believe that Calypso would allow that as they now make a line. Link to comment https://qualityforum.zeiss.com/topic/5870-maximum-material-condition-in-secondary-datum/#findComment-21920 Share on other sites More sharing options...
[Ri...] Posted April 10, 2024 Share Posted April 10, 2024 Calypso 2023 and newer will handle this with ease with the new GD&T package. 🙂 Link to comment https://qualityforum.zeiss.com/topic/5870-maximum-material-condition-in-secondary-datum/#findComment-21922 Share on other sites More sharing options...
[Ky...] Posted April 11, 2024 Share Posted April 11, 2024 Hello all, Just to add a bit, so long as the version of Calypso that Patxi is using isn't too old, you should be able to do this with using a parallel cylinder under features>special geometries. I can't remember when it was first available (2018 or 2019 I think), but I believe this sort of callout is why it was created in the first place. Link to comment https://qualityforum.zeiss.com/topic/5870-maximum-material-condition-in-secondary-datum/#findComment-21924 Share on other sites More sharing options...
