[69...] Posted March 12, 2024 Share Posted March 12, 2024 Hallo zusammen, ich benötige kurz Hilfe: In der Zeichnung ( siehe Bild 2 ) wird eine Flächenform zum Bezug A+B gefordert. Allerdings sagt er mir am CAD-Model, dass die Geometrie nicht gültig ist. ( siehe Bild 1 ) Wie kann man diese Stelle denn sonst vermessen? ( siehe blauer Kreis ) Um eine Antwort wäre ich sehr dankbar. Gruß MircoBild 1.PNGBild 2.PNG Link to comment Share on other sites More sharing options...
[Ma...] Posted March 12, 2024 Share Posted March 12, 2024 I don't know what base A and B is, but this can be done by using free form - but it looks like torus. Link to comment Share on other sites More sharing options...
[Cl...] Posted March 12, 2024 Share Posted March 12, 2024 Free form surface - Extract from faces. I don't have access to Calypso right now, but I think it's under CAD > Creating Features? Link to comment Share on other sites More sharing options...
[69...] Posted March 21, 2024 Share Posted March 21, 2024 I haven't found anything under CAD, thanks anyway Link to comment Share on other sites More sharing options...
[69...] Posted March 21, 2024 Share Posted March 21, 2024 I set 20 spatial points at this point and then joined them together in the free-form surface with point recall. Output then as a free-form surface. At least it worked. Link to comment Share on other sites More sharing options...
[Er...] Posted March 21, 2024 Share Posted March 21, 2024 CAD/Create Features just like Clark Gilbert mentioned works great. Click on Point Set, and for the Feature Drop Down select Free Form Surface, and for General Path you have a couple of options that work really well like from Surfaces, or 4 points. I use this quite often, for features like the one shown here. Link to comment Share on other sites More sharing options...
[69...] Posted March 22, 2024 Share Posted March 22, 2024 Thank you Eric It worked 🙂 But a plot output of the surface shape is not possible then, is it? >>>> see screenshot . In any case, I have not found anything 🙁 Maybe you have an idea. Many thanks in advance Link to comment Share on other sites More sharing options...
[Ma...] Posted March 23, 2024 Share Posted March 23, 2024 With my PiWeb templates i don't have plot for this either. Use CAD evaluation if it's still available. Link to comment Share on other sites More sharing options...
[69...] Posted March 25, 2024 Share Posted March 25, 2024 OK Thanks Martin Link to comment Share on other sites More sharing options...
[Er...] Posted April 9, 2024 Share Posted April 9, 2024 Also, under Cad Evaluation you can check the box for Min/Max Points, and it will tell you the best and worst result. Very useful for me when reporting adjustments needed to the machinists. Link to comment Share on other sites More sharing options...
