Positionstoleranz gemäß Abb. 4-30 und 4-31
I think you had this example some years ago.
I still think this (M) can be used in both examples. When designer make this on drawings, then he MUST consider dimension for other plane.
And if plane B has +/- tolerance, then it' allowed to turn in both directions.
Did you not get my point? Your "Bezug B Simulator" must move to the right to rotate.
These drawings are for assembly use - so this second plane needs clearance, which I assume the designer did.
Changing published images in older posts is not a good approach.
Counter-clockwise rotation would be possible if the base B of the simulator was moving. Those pictures are misleading.
