[An...] Posted March 15 Share Posted March 15 _____ Link to comment Share on other sites More sharing options...
[An...] Posted March 15 Author Share Posted March 15 _____ Link to comment Share on other sites More sharing options...
[Ma...] Posted March 18 Share Posted March 18 I think you had this example some years ago. I still think this (M) can be used in both examples. When designer make this on drawings, then he MUST consider dimension for other plane. And if plane B has +/- tolerance, then it' allowed to turn in both directions. Link to comment Share on other sites More sharing options...
[An...] Posted March 18 Author Share Posted March 18 _____ Link to comment Share on other sites More sharing options...
[Ma...] Posted March 18 Share Posted March 18 Link to comment Share on other sites More sharing options...
[Ma...] Posted March 18 Share Posted March 18 Did you not get my point? Your "Bezug B Simulator" must move to the right to rotate. These drawings are for assembly use - so this second plane needs clearance, which I assume the designer did. Link to comment Share on other sites More sharing options...
[An...] Posted March 19 Author Share Posted March 19 _____ Link to comment Share on other sites More sharing options...
[Ma...] Posted March 19 Share Posted March 19 Please sign in to view this quote. Changing published images in older posts is not a good approach. Counter-clockwise rotation would be possible if the base B of the simulator was moving. Those pictures are misleading. Link to comment Share on other sites More sharing options...
