When you select an Icon, what information is available?
I ended up settling for after the "Run" event that activates Pre-Settings to a text file by users "Stamp ID".
//01.22.24 - Setup Last User information
OpName=getRecordHead("u_OperatorName")
OpWoID=getRecordHead("u_WorkOrderID")
OpPartNumb=getRecordHead("u_PartNumb")
OpSerNumb=getRecordHead("u_SerNumb")
OpFam=getRecordHead("planid") //Program ID
Opminiselection=miniselection //Mini Plan Name
inspPath2 = "C:\Users\Public\Documents\Zeiss\CALYPSO\workarea\inspections\Zeiss 1 Block\Eaton Aerospace\PCM Program\"
//end
//fileName = OpName +".txt"
fileName = OpName+".txt"
deleteFile(inspPath2+fileName)
addToFile(inspPath2+fileName, OpName)
addToFile(inspPath2+fileName, OpWoID)
addToFile(inspPath2+fileName, OpPartNumb)
addToFile(inspPath2+fileName, OpSerNumb)
addToFile(inspPath2+fileName, OpFam)
addToFile(inspPath2+fileName, Opminiselection)
//end
Then I created a vb.NET App that reads the text file and provides information to the user.
See image: Capture.PNG
The App is opened by the user from a fixed folder location.
The App stays on Top of everything.
The user enters the Stamp ID and clicks on Search.
