[Lu...] Posted January 20, 2022 Share Posted January 20, 2022 Hello, I was wondering if its possible with GOM Inspect (free edition), to automatically make contour curves on the edges of certain inspection values. You could compare the result like a sort of 2D DEM map, but then in 3D and directly on the inspection mesh, representing region with a certain value. See the screencap, if i want a curve representing all the blue spots, done automatically based on the inspection value, is this possible. I drew here the desired result with yellow lines (3d curves) which i want to export to a CAD software like Rhino: Any suggestions how to do this in Gom Inspect? Or is this not possible? Link to comment Share on other sites More sharing options...
[Be...] Posted January 21, 2022 Share Posted January 21, 2022 Hi, unfortunately this is not possible in the moment as far as I know. You can visualize these "curves" with a discrete legend, but in the moment we don't offer any export or creation as an element which could be exported. Regards, Bernd Link to comment Share on other sites More sharing options...
[Na...] Posted January 24, 2022 Share Posted January 24, 2022 Hello, with a Pro license you could create a surface defect map and export the boundary lines of the defects with scripting. Scripting is not available in the free version though. Regards, Nanno Link to comment Share on other sites More sharing options...
