[Th...] Posted January 25, 2022 Share Posted January 25, 2022 (edited) Hi, I watched an issue with moving point clouds into a new part. Easiely to reproduce : New Project Drag an Ascii File with points into the project (target: clipboard) Save project Drag the point cloud into from clipboard a new part Name the Part "Part" Save the project After Step 3 the point cloud contains all points (after reloading the project). After Step 6 the point cloud contains "0" points (after reloading the project). Perhaps I am missing something but this looks suspicious... Best regards Thorsten 2021-12-21_14-30-30_scanunit0_parameterset2_20m_x48_TEST.asc Edited January 25, 2022 Link to comment https://qualityforum.zeiss.com/topic/660-gom-inspect-after-adding-point-cloud-to-new-part-all-points-are-deleted/ Share on other sites More sharing options...
[Je...] Posted February 4, 2022 Share Posted February 4, 2022 Hello Mr.Hojnacki, I repeated the meantioned steps. In 2021 HF4 everything works as expected. If you want you can contact support@gom.com then we can try to reproduce this behaviour with your data set and fix this if this is still appearing in current software version. Best regards, Jens Braun Link to comment https://qualityforum.zeiss.com/topic/660-gom-inspect-after-adding-point-cloud-to-new-part-all-points-are-deleted/#findComment-2061 Share on other sites More sharing options...
[Th...] Posted February 8, 2022 Author Share Posted February 8, 2022 Thank you, I will wait for the release of HF 4 and report here. Link to comment https://qualityforum.zeiss.com/topic/660-gom-inspect-after-adding-point-cloud-to-new-part-all-points-are-deleted/#findComment-2076 Share on other sites More sharing options...
[Th...] Posted February 10, 2022 Author Share Posted February 10, 2022 I think I have found the cause for this bug. My project file lies in a folder containing the german character "Ü". If I remove all "special" characters from the folder path, it works as expected. I reproduced this behaviour with GOM Inspect 2019 (Free). I am working under Windows 11. Link to comment https://qualityforum.zeiss.com/topic/660-gom-inspect-after-adding-point-cloud-to-new-part-all-points-are-deleted/#findComment-2103 Share on other sites More sharing options...
