Transfer data to Planner
AFAIK, using PCF files won't give you stylus model displays in Planner, you still need to import SSC files.
I import SSC files, making sure my nomenclature is exactly the same as my PCF on the live CMM.
I don't recall a method to transfer the data to and from other than importing probe files.
One
at
a
time...
It won't transfer the dimensions from the actual dimensions of the cmm's stylus systems. Those dimensions come from Stylus System Creator. However, all of the angles and styli names you defined on the stylus systems will be brought in and attached to the SSC version.
I am working off a phone, so this is from memory, but in Extras-Settings-Miscellaneous-System. Located in that tab there are options to Save and Restore(exact verbiage may vary based on Calypso version). The backup option creates a .bak file that can then be loaded using the Restore function, even on another PC. You are given the option of what data to backup when you create the.bak, but you will still need to load SSc files if you want to see the probes in simulation, as the online seat will most likely not have those, only pcf data.
Edited to correct menu path
