[To...] Posted December 4, 2023 Share Posted December 4, 2023 I am having a part with a theoretical cylinder constructed on a V-block. I have absolutely no idead how to construct it. The red V-block is my actual part. The blue Ø8 circle is the cylinder which I would like to construct. Any ideas on how to make this cylinder? Link to comment https://qualityforum.zeiss.com/topic/6720-constructing-theoretical-cylinder/ Share on other sites More sharing options...
[Ma...] Posted December 4, 2023 Share Posted December 4, 2023 One way using curve or other way - using 2x 2d lines and using tangent construction. Repeat as many times as you need to fill length of a part ( recalling tangent constructions into 3d line to get axis ) Link to comment https://qualityforum.zeiss.com/topic/6720-constructing-theoretical-cylinder/#findComment-27130 Share on other sites More sharing options...
[Da...] Posted December 4, 2023 Share Posted December 4, 2023 [list=1]Measure both planes of the V-block, preferably as outer tangential elements Construct both possible symmetry planes (both are perpendicular to each other) from those planes Construct an intersection line from the symmetry planes Create a new coordinate system with the intersection line as primary alignment Use the new coordinate system to construct two theoretical lines at the centroids of the V-Block planes parallel to the planes Use the tangent function with those two lines to create a tangent circle with the right diameter Construct a theoretical cylinder at the same coordinates, same direction, same diameter as the circle Tadaaa... Link to comment https://qualityforum.zeiss.com/topic/6720-constructing-theoretical-cylinder/#findComment-27132 Share on other sites More sharing options...
[Ün...] Posted December 4, 2023 Share Posted December 4, 2023 it might be useful Link to comment https://qualityforum.zeiss.com/topic/6720-constructing-theoretical-cylinder/#findComment-27134 Share on other sites More sharing options...
[To...] Posted December 4, 2023 Author Share Posted December 4, 2023 Please sign in to view this quote. Using curves and "Circel in contour"? Just found this feature, so never used it. Link to comment https://qualityforum.zeiss.com/topic/6720-constructing-theoretical-cylinder/#findComment-27136 Share on other sites More sharing options...
[Ma...] Posted December 4, 2023 Share Posted December 4, 2023 Please sign in to view this quote. Yes - circle in contour. But using planes with outer tangential -> offset plane from them by radius and cut can be done too. So many good ideas are shown here. I have similar problem unsolved - i have to measure a part ( cylinder ) and get distance from center of cylinder ( fit into this 90° piece ) to another plane. Link to comment https://qualityforum.zeiss.com/topic/6720-constructing-theoretical-cylinder/#findComment-27138 Share on other sites More sharing options...
[Jo...] Posted December 4, 2023 Share Posted December 4, 2023 Please sign in to view this quote. Not to hijack, but here is the inverse of the procedure. Use formula to get sqrt(cylinder radius) andcopy another into a rotated alignment. Then you can get intersection.root.jpgint.jpgtang.jpg Link to comment https://qualityforum.zeiss.com/topic/6720-constructing-theoretical-cylinder/#findComment-27140 Share on other sites More sharing options...
[Cl...] Posted December 4, 2023 Share Posted December 4, 2023 Please sign in to view this quote. Yet another way. Link to comment https://qualityforum.zeiss.com/topic/6720-constructing-theoretical-cylinder/#findComment-27142 Share on other sites More sharing options...
[Ma...] Posted December 4, 2023 Share Posted December 4, 2023 Please sign in to view this quote. I am not quite sure I understand your post. Are you answering to author's quiestion or mine not-solved? Mine don't need this type of intersection. I need to measure cylinder and report it's center axis distance to a plane, but center axis of a cylinder needs to be obtained like this V shape. Or i'll try to use planes with locked angle and outer tang. with recalled points from part of a cylinder - perhaps this would work for me. Link to comment https://qualityforum.zeiss.com/topic/6720-constructing-theoretical-cylinder/#findComment-27144 Share on other sites More sharing options...
