SURFACE ROUGHNESS
Hello, I'm new to the CMM community, and these forums are a great source of information, it makes my job a lot easier, so thank you all for being so active on here.
I've been tasked with finding out how to inspect a surface finish on our parts using our CMM's, one is Spectrum RDS VAST XXT, and the other one is O-Inspect 3/2/2 VAST XXT. I was wondering if they're even compatible to check surface roughness. What would be my first step in doing so? Thank you.
https://qualityforum.zeiss.com/topic/6818-surface-roughness/
Neither is compatible with Surface finish on CMM. For Surface Finish on a CMM you would need a different CMM (Prismo) with has the appropriate hardware to support ROTOS. Outside of CMM work, Zeiss does have a number of Surface finish products such as the HandySurf https://www.zeiss.com/metrology/product ... ysurf.html
or SurfCom https://www.zeiss.com/metrology/product ... amily.html
https://www.zeiss.com/metrology/product ... rface.html
https://qualityforum.zeiss.com/topic/6818-surface-roughness/#findComment-27686
  • 2 weeks later...
So this one is still a sore spot for me with Zeiss. In the 2022 release video and release notes, they said a feature being released was "roughness evaluation with any type of sensor" It's listed as feature 219486 in the 2022 release notes. Naturally, I was pretty excited about this. One less step to do, and one less step for operators to miss.
Unfortunately, it was a lie. It doesn't work with the Vast XT I've got on a Micura.
https://qualityforum.zeiss.com/topic/6818-surface-roughness/#findComment-27698
