Looking for ideas
have a prototype part that i need to count serrations (spline teeth really). Company not buying gages which is normally used for this. teeth are aprox .0165" and 279 of them. Very small. Was hoping to just scan 360 degrees then use the outliner to count but my mind is just going blank at the moment. Any thoughts?
Try using a 360 degree scan then evaluate with waviness. You should be targeting a UPR of 279 I believe.
I have no idea if this will work, but it sounds like it should.
Wouldn't it be easier to just calculate it? Measure a 3 or 4 point circle on the spline using self-center points (the method is mentioned in a similar topic viewtopic.php?t=11846)
Then take the distance between two spline teeth using self center points. Use these points to establish the angular distance and divide it into 360.
This is but one method and lots of alternative routes can come from it as well.
only problem is cutter wear... such a small tooth that can't see by eye. Just wish they get a gage and problem solved. Also looking at gear pro measuring span width .... if span width is good, and runout is good, no way there will be extra teeth or less teeth.
Remember, if you want the Fourier analysis to show 279 UPR, you will need at least 279 x 7 = 1953 points or better more. 7 points are needed minimum to define a wave.
still would be nice if i could just scan and then count the "bumps", with no calculations. Gear softwares...no matter how nice....still are not a direct measurement and usually off due to many factors, like runout.
Now i don't know how small teeths are, but what about scan 360° curve, then use 3D line with dividing? Then you know how many lines you have and you just visually check position of line on curve
