[St...] Posted October 27, 2023 Share Posted October 27, 2023 Using older Calypso software and have had a few employees come and go. Would like to be able to edit/change names in the drop down when different employees are running the programs. That way they don't have to keep typing in their names and can pick from the drop down window.Version.jpgOperator.jpg Link to comment Share on other sites More sharing options...
[To...] Posted October 27, 2023 Share Posted October 27, 2023 Not sure about your version, but if you go into Extras > Settings > User you can Add, Delete or Edit Users. Link to comment Share on other sites More sharing options...
[Je...] Posted October 27, 2023 Share Posted October 27, 2023 You need to edit your userfields.ini file. It is just a text file that contains your userfield data such as drop down texts and selection options. In modern versions of CALYPSO this is located at; C:\Users\Public\Documents\Zeiss\CALYPSO\protocol\protform Your version is under the old filepath designation but the structure is the same. 1 Link to comment Share on other sites More sharing options...
[Ri...] Posted October 27, 2023 Share Posted October 27, 2023 Has QS-STAT gone away or is it buried in the software install somewhere? Link to comment Share on other sites More sharing options...
[Ke...] Posted October 27, 2023 Share Posted October 27, 2023 Please sign in to view this quote. Despite this being unrelated to the current topic, I will go ahead and reply here in case someone in the future stumbles across this while searching: QS-Stat is a part of QDAS, an outside software owned and produced by Hexagon. It is not a part of Calypso, nor has it ever been. The interaction between Calypso and QDAS is only that Calypso can produce files usable by QDAS, which is what the QS-STAT interface does(see page 11 of the attached document). This interface is built into Calypso but requires a license.ZEISS_Software_Brochure_EN_60_011_0005I_.pdf Link to comment Share on other sites More sharing options...
[Je...] Posted October 27, 2023 Share Posted October 27, 2023 Please sign in to view this quote. Link to comment Share on other sites More sharing options...
[To...] Posted October 27, 2023 Share Posted October 27, 2023 Please sign in to view this quote. hijacker..... 🤣 Link to comment Share on other sites More sharing options...
[St...] Posted October 27, 2023 Author Share Posted October 27, 2023 Thanks Jeff. After finding the userfield.ini file it was real easy to change. Thanks for the help. Link to comment Share on other sites More sharing options...
[St...] Posted July 22 Author Share Posted July 22 (edited) We have a new employee and I went to add their name to our list. Now when I try and run a program I am getting an error message saying the following. Can anyone Help me? Edited July 22 Link to comment Share on other sites More sharing options...
[Ma...] Posted July 22 Share Posted July 22 Have you tried restarting Calypso? I don't think you have something bad in that file - i presume it was working before, you just added a line. I would try to add empty line on end of that file. Link to comment Share on other sites More sharing options...
[St...] Posted July 22 Author Share Posted July 22 Restarted Calypso and the Computer. It was working before just tried to add the new employee's name at the end. Put an empty line at the end and still does the same thing. Link to comment Share on other sites More sharing options...
[Ma...] Posted July 22 Share Posted July 22 Then i would try to save that file as ANSI instead of UTF-8 - nothing more is comming to my mind. It should be really simple action: Open file in notepad copy last line and paste it change name save it There should be no whitespace so "5=Phil M" ( without quotes ) Link to comment Share on other sites More sharing options...
[St...] Posted July 22 Author Share Posted July 22 (edited) Still doing the same thing. No dice. Is there a way to just restore it to yesterday's date? Edited July 22 Link to comment Share on other sites More sharing options...
[Ma...] Posted July 22 Share Posted July 22 Perhaps IT can revert if system has a last version. If you send me that file i can check it when i will be at work ( 12hours from now ) and send it back. Just PM me or if it's not confidential you can possibly post it here. Link to comment Share on other sites More sharing options...
[No...] Posted Thursday at 06:21 AM Share Posted Thursday at 06:21 AM Also check if you accidentally put one or more space characters at the end of a line. And of course you should avoid any kind of special chracters in your entries. Only charcters and numbers. Link to comment Share on other sites More sharing options...
[St...] Posted Friday at 09:41 AM Author Share Posted Friday at 09:41 AM We had our IT department restore the computer back to a later date and that corrected the problem. Still don't understand what went wrong. But it is corrected for now. Until I get my fingers in there again. LOL. Martin and Norbet thanks for your help. It is appreciated!! 1 Link to comment Share on other sites More sharing options...
[Ma...] Posted Friday at 09:45 AM Share Posted Friday at 09:45 AM Make a copy before editing 🙂 Link to comment Share on other sites More sharing options...
[Lu...] Posted Friday at 12:36 PM Share Posted Friday at 12:36 PM Very strange. Did you have CALYPSO and any programs open when you made the changes? Not sure if that would affect things. Link to comment Share on other sites More sharing options...
[St...] Posted Friday at 02:30 PM Author Share Posted Friday at 02:30 PM I did have Calypso open when I made the changes. Would that make the difference? Link to comment Share on other sites More sharing options...
[Ma...] Posted Friday at 03:12 PM Share Posted Friday at 03:12 PM Please sign in to view this username. I don't think so. Restarting Calypso would solve that. Link to comment Share on other sites More sharing options...
[Na...] Posted 9 hours ago Share Posted 9 hours ago Please sign in to view this quote. The thing you show in the operator window is editable under the user defined report variables. I can't remember which thing it's under in the top bar. I don't currently have Calypso access at my current job. Link to comment Share on other sites More sharing options...
