Single-flank composite testing and order spectra
Dear Friends
i have questions about version news of the release Gear pro 2023(7.0.000)
noise analysis step:
new measuring task single -flank composite testing and order spectra
who can help me interpret the meaning of the report.
Thank you very much!! ❗ ❗ ❗ ❗ 🤣 🤣 🤣
I believe this is simulated "roll-testing" with a mating or master gear - single flank only
Probably to satisfy newer EV requirements.
In theory it could be a great idea and helpful. Anyone who has roll tested a number of gears however will probably question its accuracy from a "simulation" gear. (double flank)
More info can be found in Gear Pro 2023 release notes.
The release notes themselves can be downloaded from Portal...
Inside of the Gear Pro 2023 full downloaded there is a release notes folder as well with this info.
I'll include the first page here for reference.
You most likely don't need this page and it should be able to be turned off or deactivated.
