CMM data not found
The machine has been homed. The message appears every time machine connects. CMM runs programs.
After some thought, I'm guessing this error means it can't load the correction file from the controller. Would that be a safe assumption?
That would seem like a reasonable line of thinking, though I believe that usually throws an error message about CAA file unavailable/invalid.
I know there are other things it can be, but they are so uncommon I have never encountered, or even heard of, any other than the CMM needing homed for that message. I checked out Knowledgebase as well just to see if there were any other solutions (https://portal.zeiss.com/knowledge-base ... id=1475168), and the article says essentially, home the machine, if that doesn't work it is an extremely rare issue, call support.
Maybe it helps to know that this specific message is displayed if the CAA status check fails. Calypso seems to think that the CMM has no CAA.
I had the same notice this morning (2023). I corrected by shutting down all the way (computer and CMM) and restarting. We had not homed the machine yet, so different situation. Interested to see what works for you.
  • 1 year later...
We just had an unexpected power outage at the end of the day yesterday, the UPS's for two of our three Micura 5/5/5's kept them going until they could be gracefully shut down.  Unfortunately, the other UPS was kaput.  This morning, after the power is restored, we got this message when starting Calypso for this machine.  I tried the above, but whenever it tries to home, the drives keep turning off, so it won't home.  I have a support ticket in to Zeiss, but while I'm waiting, does anyone have any thoughts?
Try slowing down the speed with the dial on the control box. We had the same thing with a contura, slowing it down was only needed for the homing. Somehow a parameter had changed and was causing our issue. Zeiss tech was able to reset and all has been fine since.
