cad setting issue
clicking on the cad on already extracted features in the features tab should take you to that extracted feature. doesn't always work. Also when i 1st run a program the primary plane blocks the cad view. Need help with the settings please.
If while on the Features tab you want to navigate to an already extracted feature, make sure this option is active on the "Select or create geometries from the CAD model" menu. This will allow you to click the feature on the CAD model. If you want to extract a feature by clicking on the CAD model, one of the bottom two options should be used.
