Feature Alignment Does Not Match Base Alignment
I would describe it like this:
Machine coordinate system -> Base alignment of program -> Own coordinate system of feature
Each of them has their own point of origin and axis directions.
Tip: If you ask for this - be carefull for 2D lines - manual scan always in same direction as nominal, otherwise if used in alignment it will rotate that alignment axis.
