[Ma...] Posted September 8, 2023 Share Posted September 8, 2023 **Relatively new to Zeiss and Calypso** I've searched the forum and was unable to find an answer. Why does the feature alignment not match the base alignment? Is that an issue? THANKS!!1Capture.PNG Link to comment https://qualityforum.zeiss.com/topic/7276-feature-alignment-does-not-match-base-alignment/ Share on other sites More sharing options...
[De...] Posted September 8, 2023 Share Posted September 8, 2023 What you are seeing is normal. No issue. However, on circles and cylinders, Calypso usually tried to enter from the +Z direction shown on the feature. Link to comment https://qualityforum.zeiss.com/topic/7276-feature-alignment-does-not-match-base-alignment/#findComment-30602 Share on other sites More sharing options...
[Ma...] Posted September 8, 2023 Share Posted September 8, 2023 I would describe it like this: Machine coordinate system -> Base alignment of program -> Own coordinate system of feature Each of them has their own point of origin and axis directions. Tip: If you ask for this - be carefull for 2D lines - manual scan always in same direction as nominal, otherwise if used in alignment it will rotate that alignment axis. Link to comment https://qualityforum.zeiss.com/topic/7276-feature-alignment-does-not-match-base-alignment/#findComment-30604 Share on other sites More sharing options...
