[Ca...] Posted September 5, 2023 Share Posted September 5, 2023 download/file.php?mode=view&id=13366&si ... 4d51fbd2e4 Hello Everyone! I am brand new to using calypso and just finished taken the basic training class. I am having trouble doing the base alignment for this part. I want to check the part like it sits but not sure how to do the alignment since i have no flat surface on the Z axis. I want my Zero to be in the center of the bore.Round.PNG Link to comment https://qualityforum.zeiss.com/topic/7290-base-alignment/ Share on other sites More sharing options...
[R...] Posted September 5, 2023 Share Posted September 5, 2023 Please sign in to view this quote. 100.PNG Link to comment https://qualityforum.zeiss.com/topic/7290-base-alignment/#findComment-30658 Share on other sites More sharing options...
[Cl...] Posted September 5, 2023 Share Posted September 5, 2023 You could use the plane as your Y0 and spatial rotation (Y-) then make a 3D line between two of the bores in the bolt pattern and use that as your planar rotation. In my example it would either be Z- or Z+ depending which bore you defined first top bore first then bottom would make the 3D line running in the Z- direction and bottom then top would be Z+. Then you can use the center bore of the part as your Z0 and X0.Base alignment.jpg Link to comment https://qualityforum.zeiss.com/topic/7290-base-alignment/#findComment-30660 Share on other sites More sharing options...
[Ca...] Posted September 5, 2023 Author Share Posted September 5, 2023 R S So do you pick one hole or 2 that are 180 degrees apart? Link to comment https://qualityforum.zeiss.com/topic/7290-base-alignment/#findComment-30662 Share on other sites More sharing options...
[R...] Posted September 6, 2023 Share Posted September 6, 2023 Please sign in to view this quote. One hole should be enough, it depends on what the drawing requirement is Link to comment https://qualityforum.zeiss.com/topic/7290-base-alignment/#findComment-30664 Share on other sites More sharing options...
[To...] Posted September 6, 2023 Share Posted September 6, 2023 Please sign in to view this quote. As you're eluding to, if one hole is identified as the tertiary datum feature, one hole would be enough. There are other things to consider. For example, if the hole pattern is just off location, aligning off one hole will rotate the part alignment, throwing other features off, making it difficult to understand what is happening to the results.. By aligning using a 3d Line between 2 circles, the hole pattern stays oriented as machined and the location deviations can be more easily identified. Link to comment https://qualityforum.zeiss.com/topic/7290-base-alignment/#findComment-30666 Share on other sites More sharing options...
