[Le...] Posted March 15, 2022 Share Posted March 15, 2022 I'm trying to login to the GOM suite, and once again the login error appears. Has anyone managed to solve it and can you help me please? The error is " the received access authorization is invalid" Link to comment https://qualityforum.zeiss.com/topic/737-login-error-again/ Share on other sites More sharing options...
[Ka...] Posted March 16, 2022 Share Posted March 16, 2022 Dear Leticia, unfortunately we still do not know which version you are using. In GOM Suite, please go to Maintenance, click on Collect Support Data, wait until the process finished, which may take up to 10 minutes and send us the gomsic-report-2022-xxxx.tgz file via email together with a short description of the issue to support@gom.com. Link to comment https://qualityforum.zeiss.com/topic/737-login-error-again/#findComment-2261 Share on other sites More sharing options...
[Mi...] Posted March 24, 2022 Share Posted March 24, 2022 Hi. I had the same issue and this seems to work for me... 1. Open GOM Suite and attempt to log in 2. Open a browser and go to 'My GOM' 3. Sign in on the My Gom site in the browser 4. Back in GOM Suite sign in. 5. GOM Suite should now remember your credentials for future use. Let me know if this works for you... Link to comment https://qualityforum.zeiss.com/topic/737-login-error-again/#findComment-2340 Share on other sites More sharing options...
[Fa...] Posted March 31, 2022 Share Posted March 31, 2022 (edited) Hi there, I've had issue with gom Suite login for quite some time now "Bad Request Too Long" Se pic! Is there anyone who has the same problem? and possibly know how to fix it? Edited March 31, 2022 Link to comment https://qualityforum.zeiss.com/topic/737-login-error-again/#findComment-2399 Share on other sites More sharing options...
[14...] Posted April 1, 2022 Share Posted April 1, 2022 To solve this you have to delete the Cefsharp Cache. Open (WIN + R) "Run" Menu. Enter "%appdata%". Navigate to folder ... AppData/Local/Cefsharp/. Delete the "Cache" folder. Restart the GOM Suite several times (close it in the system tray completely!) and test if you can log in now. It should work now. Link to comment https://qualityforum.zeiss.com/topic/737-login-error-again/#findComment-2405 Share on other sites More sharing options...
[Fa...] Posted April 4, 2022 Share Posted April 4, 2022 Thanks, It worked 🙂 Link to comment https://qualityforum.zeiss.com/topic/737-login-error-again/#findComment-2411 Share on other sites More sharing options...
