Video: cmm walking the tightrope
Hi!
Ever watched a cmm walk the tightrope? These parts have a large deviation due to welding. To measure the part correctly I used the edge curve function.
I just found out about this function when it was brand new - a couple of Calypso releases ago. Few days later I received an inquiry for this job. ☺️ With a little help from my Zeiss application engineer it turned out to be a cool job.
Made the video for my clients and prospects so it's in Dutch. I'm sure you'll get the point nontheless.
https://youtu.be/gPTf1dnNhRI
This is very interesting. When I search Calypso help for Edge Curve, I do not find anything. Would you please describe the process in simple terms? Thank you.
As far as my knownledge goes i would scan side close to main path as curve, then use alignment from curves and then measure main path.
I don't believe there is such function which would correct whole main curve by scanning side - it would just help with position and not altering nominals 😱
I'm not sure, since I don't use Curve (yet) but I think it measures a reference curve at the sides and follows it when scanning the outside. Or something like that...
You could have Calypso make an edge curve automatically. By the menu Tom showed.
That didn't work for my screws. Since I couldn't have the approach point the way I wanted them. Not for the edge curve that is...
You can also have another curve as the edge curve. I copied the original curve that I wanted to inspect. Moved the points a bit and rotated them 90 degrees around their tangent.
Make sure both curves have the same number of points.
  • 1 month later...
  • 4 months later...
