[Br...] Posted August 4, 2023 Share Posted August 4, 2023 Hi, our customer has requested a point list with coordinates for each point on a couple features to input into DMIS, how would I go about that? I have exported the zmp file and sent that to them, but i am not sure if that is enough, plus it would be kind of humourous to know they are inputting 3,000+ points by hand. Link to comment https://qualityforum.zeiss.com/topic/7424-xyz-coordinate-export/ Share on other sites More sharing options...
[Jo...] Posted August 4, 2023 Share Posted August 4, 2023 Go to the features list and highlight the one you want to export from. Right mouse click "export points" and choose which way you want to extract. It will give you x y z coordinates for each point of the feature in a file. Link to comment https://qualityforum.zeiss.com/topic/7424-xyz-coordinate-export/#findComment-31416 Share on other sites More sharing options...
[Ke...] Posted August 4, 2023 Share Posted August 4, 2023 Yeah... they are probably using touch points and are expecting maybe a dozen or so points 🤣 I have seen supliers that only use 6 totally random points to generate a flatness result. Link to comment https://qualityforum.zeiss.com/topic/7424-xyz-coordinate-export/#findComment-31418 Share on other sites More sharing options...
[Je...] Posted August 4, 2023 Share Posted August 4, 2023 Please sign in to view this quote. . Joe, or anyone else... How do I automate this process? I have "export points" activated in the "results to file" dialog. I also have defined the location to where these points are to be saved by using the "name of output file variable" option in the "Name definitions for output files..." dialog. However, at the end of a cnc run, no points are being output. What am I missing? . . . Link to comment https://qualityforum.zeiss.com/topic/7424-xyz-coordinate-export/#findComment-31420 Share on other sites More sharing options...
[To...] Posted August 4, 2023 Share Posted August 4, 2023 Go into Features Setting Editor You may need to add a file ending, i.e. +".txt"Screenshot 2023-08-04 124633.jpgScreenshot 2023-08-04 124657.jpg Link to comment https://qualityforum.zeiss.com/topic/7424-xyz-coordinate-export/#findComment-31422 Share on other sites More sharing options...
[Je...] Posted August 4, 2023 Share Posted August 4, 2023 Please sign in to view this quote. . Thanks, Tom! That worked great. . Link to comment https://qualityforum.zeiss.com/topic/7424-xyz-coordinate-export/#findComment-31424 Share on other sites More sharing options...
[Br...] Posted August 14, 2023 Author Share Posted August 14, 2023 Please sign in to view this quote. they are, that's why i want to send them the ~1,800 point list. Link to comment https://qualityforum.zeiss.com/topic/7424-xyz-coordinate-export/#findComment-31426 Share on other sites More sharing options...
[Je...] Posted August 16, 2023 Share Posted August 16, 2023 Please sign in to view this quote. Did you review the ZEISS PORTAL KNOWLEDGE BASE? https://portal.zeiss.com/knowledge-base ... id=1793221 https://portal.zeiss.com/knowledge-base ... id=1895328 Link to comment https://qualityforum.zeiss.com/topic/7424-xyz-coordinate-export/#findComment-31428 Share on other sites More sharing options...
