[Jo...] Posted August 14, 2023 Share Posted August 14, 2023 Hi, I measured 2 pts, 360° around in a pattern like a timing sprocket and now want to get the 2pt/ 3d distances of those all those 720 pts. Is there a fast way of doing this like in a loop in the characteristics? Thanks! Link to comment https://qualityforum.zeiss.com/topic/7426-3d-distance-loop/ Share on other sites More sharing options...
[Ch...] Posted August 14, 2023 Share Posted August 14, 2023 yes simply select the patterned feature .. done. Link to comment https://qualityforum.zeiss.com/topic/7426-3d-distance-loop/#findComment-31432 Share on other sites More sharing options...
[Jo...] Posted August 14, 2023 Author Share Posted August 14, 2023 Indeed. Thanks! Link to comment https://qualityforum.zeiss.com/topic/7426-3d-distance-loop/#findComment-31434 Share on other sites More sharing options...
[Jo...] Posted August 15, 2023 Author Share Posted August 15, 2023 Please sign in to view this quote. That worked with the distances and symmetry points same way. I wanted to get the angle of each symmetry point from center of the circle, but everything came up 0° for all 360 pts so I have something wrong. I used angle between features and putbthe loop of 360 symmetry points in feature 1 and circle in the other. I then created a 3d axis at 12 O'clock and repl;aced circle but that just errored out Calypso. What would be the proper way? Thanks! Link to comment https://qualityforum.zeiss.com/topic/7426-3d-distance-loop/#findComment-31436 Share on other sites More sharing options...
