3d distance loop
Hi,
I measured 2 pts, 360° around in a pattern like a timing sprocket and now want to get the 2pt/ 3d distances of those all those 720 pts. Is there a fast way of doing this like in a loop in the characteristics?
Thanks!
That worked with the distances and symmetry points same way. I wanted to get the angle of each symmetry point from center of the circle, but everything came up 0° for all 360 pts so I have something wrong. I used angle between features and putbthe loop of 360 symmetry points in feature 1 and circle in the other. I then created a 3d axis at 12 O'clock and repl;aced circle but that just errored out Calypso. What would be the proper way? Thanks!
