CMM Models
Looks like a proprietary file format. The file header says "ZeissVFF Caligo Model Facet".
I'm pretty sure the ACIS core is able to read it (like it also does with the stylus models contained in SSC files), but unfortunately it doesn't save.
Hmmm.....maybe it's possible to load with ACIS, then save as SAT? This would require to enter the correct commands in the ACIS window. Must investigate.....some day.....when I have time.... 🙁
https://qualityforum.zeiss.com/topic/7430-cmm-models/#findComment-31448
  • 1 year later...
That was some time ago. When we're planning out a machining cell with robotics, we use models of all the equipment to verify the layout. Sometimes, the customer wants a cmm, or two, in the cell, so having the model of the cmm makes it more complete.
https://qualityforum.zeiss.com/topic/7430-cmm-models/#findComment-31456
Tom,
If you need models for machines, contact your RSM and they should be able accommodate those needs on a case-by-case basis. The VFF models are not able to be utilized but STP models may be available upon request but they must run through your RSM for coordination with our Engineering departments.
https://qualityforum.zeiss.com/topic/7430-cmm-models/#findComment-31460
