[Pe...] Posted August 2, 2023 Share Posted August 2, 2023 I am having a problem with the cnc requalification of a probe. I have an "L" shaped probe that, when rotated to A0.0° B0.0°, points in -Y. When I import it, it has the vector properly at X0.00000 Y-1.00000 Z0.00000. Then I do a manual qualification which runs fine, but it overwrites the vector to X0.00000 Y0.00000 Z-1.00000 and grays out the values so they cant be changed. Afterwards if I try to run the cnc qualification program it treats the probe as if it were a -Z and of course bonks onto the probe shaft. Link to comment https://qualityforum.zeiss.com/topic/7452-probe-qualification-overwriting-probe-vector/ Share on other sites More sharing options...
[Mi...] Posted August 2, 2023 Share Posted August 2, 2023 Just to be perfectly clear... For that -Y (Front) facing probe... you are probing it in the middle of the +Y(Back) side of the calibration sphere when you do it manually correct? Link to comment https://qualityforum.zeiss.com/topic/7452-probe-qualification-overwriting-probe-vector/#findComment-31560 Share on other sites More sharing options...
[Pe...] Posted August 2, 2023 Author Share Posted August 2, 2023 Please sign in to view this quote. Yes This is what it looks like after qualification: Link to comment https://qualityforum.zeiss.com/topic/7452-probe-qualification-overwriting-probe-vector/#findComment-31562 Share on other sites More sharing options...
[Ri...] Posted August 3, 2023 Share Posted August 3, 2023 Please sign in to view this quote. I'm pretty sure when I created this type of probe my vectors were X0, Y0, Z-1 at A0B0. When qualifying I probed from the axis direction of the stylus. Link to comment https://qualityforum.zeiss.com/topic/7452-probe-qualification-overwriting-probe-vector/#findComment-31564 Share on other sites More sharing options...
[To...] Posted August 3, 2023 Share Posted August 3, 2023 A stylus in the -Y direction should be 0 / -1 / 0 Link to comment https://qualityforum.zeiss.com/topic/7452-probe-qualification-overwriting-probe-vector/#findComment-31566 Share on other sites More sharing options...
[Ri...] Posted August 3, 2023 Share Posted August 3, 2023 This is how I build them. Then I qualify by probing in the Y axis.Capture.JPG Link to comment https://qualityforum.zeiss.com/topic/7452-probe-qualification-overwriting-probe-vector/#findComment-31568 Share on other sites More sharing options...
[To...] Posted August 4, 2023 Share Posted August 4, 2023 Please sign in to view this quote. You're in Planner. Trying looking a the data on a machine. Link to comment https://qualityforum.zeiss.com/topic/7452-probe-qualification-overwriting-probe-vector/#findComment-31570 Share on other sites More sharing options...
[Mi...] Posted August 4, 2023 Share Posted August 4, 2023 One suggestion I would have is to probe off center, just far enough to make it ask you for the angle. Then you correct both angles to 0 if this is a straight -Y facing probe. I always use this technique when doing any kind of angled probe, I don't even try to probe on the correct angle and just input the correct values after. However I have also used it to at least start with the correct angle with probes that aren't cooperating. Link to comment https://qualityforum.zeiss.com/topic/7452-probe-qualification-overwriting-probe-vector/#findComment-31572 Share on other sites More sharing options...
[To...] Posted August 4, 2023 Share Posted August 4, 2023 Perry, I just noticed this is an RDS-CAA stylus system. I am not familiar with the vector results for a stylus not in the -Z direction. Link to comment https://qualityforum.zeiss.com/topic/7452-probe-qualification-overwriting-probe-vector/#findComment-31574 Share on other sites More sharing options...
[Pe...] Posted August 4, 2023 Author Share Posted August 4, 2023 Please sign in to view this quote. There is something very odd going on that I don't understand. This is how mine is in simulation (I didn't build so maybe something is setup wrong?): But once I export it and go over to the cmm, and qualify it, that's when it changes over to the -Z vector and greys them out. It qualifies just fine when manually started. Its just the CNC qualification then treats it like a straight down probe. Link to comment https://qualityforum.zeiss.com/topic/7452-probe-qualification-overwriting-probe-vector/#findComment-31576 Share on other sites More sharing options...
[Ri...] Posted August 7, 2023 Share Posted August 7, 2023 Please sign in to view this quote. I recall sending you one or two SSC files for an "L" probe setup. Did you use them or have issues qualifying? Link to comment https://qualityforum.zeiss.com/topic/7452-probe-qualification-overwriting-probe-vector/#findComment-31578 Share on other sites More sharing options...
[To...] Posted August 7, 2023 Share Posted August 7, 2023 Please sign in to view this quote. Honestly, I don't recall and I also can't find the email that you sent. Link to comment https://qualityforum.zeiss.com/topic/7452-probe-qualification-overwriting-probe-vector/#findComment-31580 Share on other sites More sharing options...
[Ri...] Posted August 7, 2023 Share Posted August 7, 2023 Please sign in to view this quote. viewtopic.php?p=48772#p48772 Link to comment https://qualityforum.zeiss.com/topic/7452-probe-qualification-overwriting-probe-vector/#findComment-31582 Share on other sites More sharing options...
[To...] Posted August 7, 2023 Share Posted August 7, 2023 Please sign in to view this quote. Yes, now I remember. You qualified it with the probe in the -Z direction so your vectors would be X0/Y0/Z-1. The original poster's probe is in the Y direction. Now, the question is when using an L stylus do you have to qualify in the probe in the -Z direction or can you qualify it at A0B0? Link to comment https://qualityforum.zeiss.com/topic/7452-probe-qualification-overwriting-probe-vector/#findComment-31584 Share on other sites More sharing options...
[Pe...] Posted August 8, 2023 Author Share Posted August 8, 2023 Please sign in to view this quote. It does qualify at A0B0, at least manually when I touch off to the back of the sphere. Then it does its swirly scan and then the 12 position points with no problems. Its just trying to run it from a qualification program that has the issues in that it begins to treat it like a -Z probe and therefore probes down onto the shaft. I hate the fact that this probe is in -Y and not X so the rotation wont allow it to probe up/down which seems a lot more versatile. But it would mean 1000's of programs would need be changed if modified. I did actually get it working once to where it could run from our qualification program but that was also on 2019 (now on 2022) so I don't know if that made a difference or no. And I also have no idea what I did to get it working. Link to comment https://qualityforum.zeiss.com/topic/7452-probe-qualification-overwriting-probe-vector/#findComment-31586 Share on other sites More sharing options...
