[Ba...] Posted July 11, 2023 Share Posted July 11, 2023 Hallo, gibt es eine Möglichkeit das Programm auf dem Messmaschinenrecher zu simulieren ohne das die Maschine bewegt werden muß? Softwarestand Calypso 2021 7.2 Danke für die Info. Link to comment https://qualityforum.zeiss.com/topic/7592-simulation/ Share on other sites More sharing options...
[No...] Posted July 11, 2023 Share Posted July 11, 2023 Kommt darauf an was du unter "Simulation" verstehst. Du kannst in den Einstellungen unter KMG oben das Häkchen bei Simulationsmodus setzen und dann die Maschine neu verbinden. Dann ist die Maschine von Calypso abgekoppelt und bewegt sich nicht, aber du hast sämtliche Funktionen und Taster verfügbar und kannst das Programm ablaufen lassen. Aber das ist natürlich keine richtige Simulation wie bei der entsprechenden Option, sondern nur ein theoretisches Durchrechnen des Programms. Link to comment https://qualityforum.zeiss.com/topic/7592-simulation/#findComment-32376 Share on other sites More sharing options...
[Je...] Posted July 11, 2023 Share Posted July 11, 2023 Please sign in to view this quote. . Yes, yes you can. . Link to comment https://qualityforum.zeiss.com/topic/7592-simulation/#findComment-32378 Share on other sites More sharing options...
[Ke...] Posted July 11, 2023 Share Posted July 11, 2023 If you are meaning to watch the CMM's travel simulated on the computer, it would depend on if you have the appropriate license for simulating measurement plans (unusual for a CMM seat to have this). If you would like, post a screenshot of the licenses showing in the Extras->Settings->Miscellaneous subwindow (you are looking for either Planner or Simulation, I forget which allows you to see a simulation of the movement). If you are meaning just simulating the results, then Jeff is correct, simply putting the CMM tab into Simulation will work. Link to comment https://qualityforum.zeiss.com/topic/7592-simulation/#findComment-32380 Share on other sites More sharing options...
[Je...] Posted July 11, 2023 Share Posted July 11, 2023 Simulation of the machine operation in a virtual manner requires the "Planner" option. Establishing a connection under "Simulation Only" allows you to run the full calculation of the program as if the stylus probed all features at nominal location but you will not be able to represent the CMM/Stylus on-screen via graphic models to prove navigation/fit during simulation. This option is typically reserved for "Offline" seats. CALYPSO running a CMM will have a "CNC" license enabled. OFFLINE seats will not usually have a CNC option and will instead have "Simulation". "Simulation" and "Planner" are usually both present on OFFLINE/PLANNER seats. Link to comment https://qualityforum.zeiss.com/topic/7592-simulation/#findComment-32382 Share on other sites More sharing options...
[Ba...] Posted July 13, 2023 Author Share Posted July 13, 2023 Hallo, ich habe das mit dem Ausschalten der Maschine versucht. Ist nicht wirklich zielführend. Die Sumulation Inklusive Maschine, RDS, Sensor und Taster wäre Toll. Es sollen ja Kollisionen vermieden werden! Kann das der Planner? Link to comment https://qualityforum.zeiss.com/topic/7592-simulation/#findComment-32384 Share on other sites More sharing options...
[Da...] Posted July 13, 2023 Share Posted July 13, 2023 Please sign in to view this quote. Yes, you can do that with planner. Link to comment https://qualityforum.zeiss.com/topic/7592-simulation/#findComment-32386 Share on other sites More sharing options...
[No...] Posted July 13, 2023 Share Posted July 13, 2023 Please sign in to view this quote. Sagen wir mal ja, zu 97% 😉 Der Rest sind Bugs. Aber Vorsicht, es gibt zwei getrennte Optionen, Planner und Simulation. Früher war das eins, und damals haben wir auch unsere Offlinestation gekauft. Ich weiß somit nicht, wo genau die Trennlinie verläuft. Am besten von Zeiss beraten lassen. Link to comment https://qualityforum.zeiss.com/topic/7592-simulation/#findComment-32388 Share on other sites More sharing options...
