[Da...] Posted March 24, 2022 Share Posted March 24, 2022 (edited) Have two diviosin points i cannot make lines or planes i have to measure symetry of this points. i made some alignment with one of points in center and other elements but when i want to select symetry and try to select second point as element its not working why ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? even 20 years cmm programs can select points as symetry elements :D:D why this one cant ? i tried to make some rotated plane on this point but it also cannot be selected for symetry . how to solve this problem ? its atos 2019 Edited March 24, 2022 Link to comment https://qualityforum.zeiss.com/topic/762-how-to-measure-symetry-of-two-points/ Share on other sites More sharing options...
[Ch...] Posted March 25, 2022 Share Posted March 25, 2022 Not knowing the exact details of your problem, my first guess for a solution (or at least a workaround) would be to create a division point from the two division points and then check that point for GD&T position with a suitable datum system (which may be as simple as the nominal point itself). In order to receive more detailed support you will have to contact the support team with your project. Link to comment https://qualityforum.zeiss.com/topic/762-how-to-measure-symetry-of-two-points/#findComment-2350 Share on other sites More sharing options...
[Da...] Posted April 14, 2022 Author Share Posted April 14, 2022 thank you Link to comment https://qualityforum.zeiss.com/topic/762-how-to-measure-symetry-of-two-points/#findComment-2521 Share on other sites More sharing options...
