[K...] Posted June 27, 2023 Share Posted June 27, 2023 I established a cylinder by using 3 circles in strategy. How can I define diameter size of all circles in characteristic. Thank you Link to comment https://qualityforum.zeiss.com/topic/7658-cylinder-characteristic/ Share on other sites More sharing options...
[Ke...] Posted June 27, 2023 Share Posted June 27, 2023 Are you looking to report the diameter of each of the 3 circles, or do you want each of the 3 circles measuring the cylinder to measure different diameters? Link to comment https://qualityforum.zeiss.com/topic/7658-cylinder-characteristic/#findComment-32870 Share on other sites More sharing options...
[K...] Posted June 27, 2023 Author Share Posted June 27, 2023 Yes, report the diameter of each of the 3 circles. Link to comment https://qualityforum.zeiss.com/topic/7658-cylinder-characteristic/#findComment-32872 Share on other sites More sharing options...
[Ka...] Posted June 28, 2023 Share Posted June 28, 2023 Hi K, Simply create a new circle, call back the points of one of the defined circles of the cylinder. Do this three times for each cylinder circle. To see the path ( cricle ) of the cylinder use right mouse button. Have fun Karsten4-Zylinder_3_circles.png3-Create_new_Cricle.png2-Call_back_point_fron_cylinder.png1-Choos the single cricle from cylinder.png Link to comment https://qualityforum.zeiss.com/topic/7658-cylinder-characteristic/#findComment-32874 Share on other sites More sharing options...
[Mi...] Posted June 29, 2023 Share Posted June 29, 2023 Please sign in to view this quote. Karsten... something similar for plane? Link to comment https://qualityforum.zeiss.com/topic/7658-cylinder-characteristic/#findComment-32876 Share on other sites More sharing options...
[K...] Posted June 30, 2023 Author Share Posted June 30, 2023 Thank you Karsten Link to comment https://qualityforum.zeiss.com/topic/7658-cylinder-characteristic/#findComment-32878 Share on other sites More sharing options...
[K...] Posted June 30, 2023 Author Share Posted June 30, 2023 Thank you Karsten Link to comment https://qualityforum.zeiss.com/topic/7658-cylinder-characteristic/#findComment-32880 Share on other sites More sharing options...
[Ma...] Posted June 30, 2023 Share Posted June 30, 2023 Please sign in to view this quote. I am not uderstanding your question. Every element has this feature - if you have more than one strategy path, then it can be recalled individually. One thing to note - pay attention if you are using strategy selector for a measuring plan Link to comment https://qualityforum.zeiss.com/topic/7658-cylinder-characteristic/#findComment-32882 Share on other sites More sharing options...
[Mi...] Posted June 30, 2023 Share Posted June 30, 2023 Sorry i thought .... if is possible to recal points from plane, points that form a plane f.e. plane from 4 points Link to comment https://qualityforum.zeiss.com/topic/7658-cylinder-characteristic/#findComment-32884 Share on other sites More sharing options...
[Ma...] Posted June 30, 2023 Share Posted June 30, 2023 Please sign in to view this quote. Yes - you can recall whole element points, or selected paths, or selected single points or range of points. Right click on element for recall - select Open for view startegy paths - or you can click Add to add custom selected points ( aka box, range, single ) - Look into manual for that Link to comment https://qualityforum.zeiss.com/topic/7658-cylinder-characteristic/#findComment-32886 Share on other sites More sharing options...
