Cylinder characteristic
Hi K,
Simply create a new circle, call back the points of one of the defined circles of the cylinder. Do this three times for each cylinder circle. To see the path ( cricle ) of the cylinder use right mouse button.
Have fun
Karsten
4-Zylinder_3_circles.png3-Create_new_Cricle.png2-Call_back_point_fron_cylinder.png1-Choos the single cricle from cylinder.png
https://qualityforum.zeiss.com/topic/7658-cylinder-characteristic/#findComment-32874
Yes - you can recall whole element points, or selected paths, or selected single points or range of points.
Right click on element for recall - select Open for view startegy paths - or you can click Add to add custom selected points ( aka box, range, single ) - Look into manual for that
https://qualityforum.zeiss.com/topic/7658-cylinder-characteristic/#findComment-32886
