[K...] Posted June 27, 2023 Share Posted June 27, 2023 I established a cylinder by using 3 circles in strategy. How can I define diameter size of all circles in characteristic. Thank you Link to comment Share on other sites More sharing options...
[Ke...] Posted June 27, 2023 Share Posted June 27, 2023 Are you looking to report the diameter of each of the 3 circles, or do you want each of the 3 circles measuring the cylinder to measure different diameters? Link to comment Share on other sites More sharing options...
[K...] Posted June 27, 2023 Author Share Posted June 27, 2023 Yes, report the diameter of each of the 3 circles. Link to comment Share on other sites More sharing options...
[Ka...] Posted June 28, 2023 Share Posted June 28, 2023 Hi K, Simply create a new circle, call back the points of one of the defined circles of the cylinder. Do this three times for each cylinder circle. To see the path ( cricle ) of the cylinder use right mouse button. Have fun Karsten 4-Zylinder_3_circles.pngFetching info... 3-Create_new_Cricle.pngFetching info... 2-Call_back_point_fron_cylinder.pngFetching info... 1-Choos the single cricle from cylinder.pngFetching info... Link to comment Share on other sites More sharing options...
[Mi...] Posted June 29, 2023 Share Posted June 29, 2023 Please sign in to view this quote. Karsten... something similar for plane? Link to comment Share on other sites More sharing options...
[K...] Posted June 30, 2023 Author Share Posted June 30, 2023 Thank you Karsten Link to comment Share on other sites More sharing options...
[Ma...] Posted June 30, 2023 Share Posted June 30, 2023 Please sign in to view this quote. I am not uderstanding your question. Every element has this feature - if you have more than one strategy path, then it can be recalled individually. One thing to note - pay attention if you are using strategy selector for a measuring plan Link to comment Share on other sites More sharing options...
[Mi...] Posted June 30, 2023 Share Posted June 30, 2023 Sorry i thought .... if is possible to recal points from plane, points that form a plane f.e. plane from 4 points Link to comment Share on other sites More sharing options...
[Ma...] Posted June 30, 2023 Share Posted June 30, 2023 Please sign in to view this quote. Yes - you can recall whole element points, or selected paths, or selected single points or range of points. Right click on element for recall - select Open for view startegy paths - or you can click Add to add custom selected points ( aka box, range, single ) - Look into manual for that Link to comment Share on other sites More sharing options...
