[Ri...] Posted June 23, 2023 Share Posted June 23, 2023 What does this error mean and how do I fix it? Its happened twice now on new adapters. During a probe change, the CMM will move into the Pocket to drop off the Probe and then pull back out and error out.Error with stylus system change.JPG Link to comment Share on other sites More sharing options...
[Cl...] Posted June 23, 2023 Share Posted June 23, 2023 Just a thought. Have you tried deleting then reassigning the stylus to the holder? Link to comment Share on other sites More sharing options...
[Ri...] Posted June 23, 2023 Author Share Posted June 23, 2023 Just tried your suggestion, same issue. This is randomly happening to a few probes for no known reason. I can move it to another Pod and it works fine. This is a brand new Prismo and this, this is just ... 🙄 I'm not sure its the adaptors now. Link to comment Share on other sites More sharing options...
[Cl...] Posted June 23, 2023 Share Posted June 23, 2023 Maybe needs the service pack? Link to comment Share on other sites More sharing options...
[Da...] Posted June 23, 2023 Share Posted June 23, 2023 Device activator from download portal might help. Link to comment Share on other sites More sharing options...
[Ri...] Posted June 26, 2023 Author Share Posted June 26, 2023 I had ran that, it did not resolve the problem. Link to comment Share on other sites More sharing options...
[Xi...] Posted June 26, 2023 Share Posted June 26, 2023 we had run same error on Accura machine, if same adapter plate is working in other pockets to adjust the pocket squareness( left to right , or front to back). if same error pop up on different pockets, the plate has quality issue even it ordered from Zeiss. Link to comment Share on other sites More sharing options...
