[Ri...] Posted June 21, 2023 Share Posted June 21, 2023 Is it possible to use PCM to run a Subsequent Evaluation after a part has ran? Link to comment https://qualityforum.zeiss.com/topic/7700-use-pcm-to-run-a-quotsubsequent-evaluationquot/ Share on other sites More sharing options...
[Wo...] Posted June 23, 2023 Share Posted June 23, 2023 Hallo Rick, unter "Vorbereiten"-"Ergebnisse auf Datei" kannst du "Messpunkte" anwählen. Unter "Datei"-"Messpunkte laden" werden die Abläufe zurück gerufen und können so nachträglich ausgewertet werden. PCM ist nicht nötig. Gruß Wolfgang Link to comment https://qualityforum.zeiss.com/topic/7700-use-pcm-to-run-a-quotsubsequent-evaluationquot/#findComment-33170 Share on other sites More sharing options...
[Ri...] Posted June 23, 2023 Author Share Posted June 23, 2023 Please sign in to view this quote. Thank you, but I am looking for a method to automate this for special testing. Link to comment https://qualityforum.zeiss.com/topic/7700-use-pcm-to-run-a-quotsubsequent-evaluationquot/#findComment-33172 Share on other sites More sharing options...
[Je...] Posted June 26, 2023 Share Posted June 26, 2023 No need to reinvent the wheel here. The work has been done. Review: 8-67 of CY22 Basic ManualAutomatic Subsequent Evaluation.pdf Link to comment https://qualityforum.zeiss.com/topic/7700-use-pcm-to-run-a-quotsubsequent-evaluationquot/#findComment-33174 Share on other sites More sharing options...
[Ri...] Posted June 26, 2023 Author Share Posted June 26, 2023 Is there information on what is required in regards to licensing? Does the evaluation PC require a Calypso software purchase? FACS/SIPOS? Link to comment https://qualityforum.zeiss.com/topic/7700-use-pcm-to-run-a-quotsubsequent-evaluationquot/#findComment-33176 Share on other sites More sharing options...
