[Ri...] Posted June 5, 2023 Share Posted June 5, 2023 I can't figure out why I can't set a 2d Line to be perpendicular to a surface using two datums. The selection for Parallel or Perpendicular is grayed out. See images. Any help is appreciated. Calypso v2019 latest rev level.Datums M, C, A-B.jpgPer_M to C_A_B not working.JPG Link to comment Share on other sites More sharing options...
[Ja...] Posted June 5, 2023 Share Posted June 5, 2023 How could your tolerance zone be perpendicular to C and A-B simultaneously? [img]https://res.cloudinary.com/engineering- ... t8tvai.jpg[/img] Ignore the part in blue there, this was the first image I could find from y14.5. Link to comment Share on other sites More sharing options...
[Ri...] Posted June 5, 2023 Share Posted June 5, 2023 It wouldn't be a 2d Line either way. It should be a 3d Line. Link to comment Share on other sites More sharing options...
[Ri...] Posted June 5, 2023 Author Share Posted June 5, 2023 Please sign in to view this quote. Datum M is perpendicular to Datum C Datum M is perpendicular to Datum A-B I don't see why it can't. Link to comment Share on other sites More sharing options...
[Ri...] Posted June 5, 2023 Author Share Posted June 5, 2023 Please sign in to view this quote. A 3D Line did not make a difference. Link to comment Share on other sites More sharing options...
[Ja...] Posted June 5, 2023 Share Posted June 5, 2023 Here's another thread on the topic: viewtopic.php?t=10632&hilit=perpendicularity+two+datums The tolerance zone will be perfectly perpendicular to the actual feature C. If its then perfectly perpendicular to the actual feature A-B it will no longer be perfectly perpendicular to the actual feature C, unless your part is perfect. But in this instance the tolerance zone could be perpendicular to C and parallel to A-B. Link to comment Share on other sites More sharing options...
[Ri...] Posted June 5, 2023 Share Posted June 5, 2023 Please sign in to view this quote. I assume it's trying to control the Perpendicularity from A-B in the X-Y Plane. I tried Parallel Cylinder but that didn't work. What about if you measured Circles at the Top and Bottom of each Cylinder and then Recalled the Center-Points into a Plane? It seems to work in principle in Simulation. Thoughts? Link to comment Share on other sites More sharing options...
[Ma...] Posted June 6, 2023 Share Posted June 6, 2023 I think that lines should not work in this cas, but planes should. Create 3d line from recalled cylinders/circles to obtain angle. Then use formulas for new theoretical plane, where you use angle in same axis to get that parallel with 3d line. Link to comment Share on other sites More sharing options...
[Er...] Posted June 6, 2023 Share Posted June 6, 2023 I think this goes back to the can, may, must rule. If the datums were set up as lines both could be applied. Link to comment Share on other sites More sharing options...
[Ri...] Posted June 6, 2023 Author Share Posted June 6, 2023 Please sign in to view this quote. I will give that a try. Link to comment Share on other sites More sharing options...
[Je...] Posted June 6, 2023 Share Posted June 6, 2023 Please sign in to view this quote. Erik has hit the nail on the head. This falls on Can-May-Must rule. Since the primary datum controls all DOF that the secondary would (and then 1 additional), the secondary datums controls are ignored. Once the "check box" is ticked in order of priority, they are no longer relevant from datums further down the list. In order to evaluate -M- to Datum -C- and the -A-B- line (3d line btw; 2d = measured, 3d = constructed) they would need to be separate characteristics. If a print shows this tolerance in a single perpendicularity requirement, I would send this back to the designer for review. Link to comment Share on other sites More sharing options...
