Measurement Plane Editor Sluggish
Installed Calypso 2023 and have noticed a stunning difference in performance when using the measurement plan editor. The window takes a couple of seconds to load as well as when switching to different settings parameters within the window.
Has anyone else experienced this same thing with 2023?
https://qualityforum.zeiss.com/topic/7864-measurement-plane-editor-sluggish/
Each version of Calypso uses a different ACIS and VWNT revision, so you could try the steps found in the WSAECONNRESET knowledgebase article (https://portal.zeiss.com/knowledge-base ... id=1596796) nominally it is for a specific error, but the steps included may also speed up the graphical handling in Calypso.
