[Sc...] Posted May 23, 2023 Share Posted May 23, 2023 Is it possible to make to check filters as a default when I extract features off the 3d model? I do quite do a lot of probe scanning. I have to check mark every feature I extracted. Link to comment https://qualityforum.zeiss.com/topic/7888-featuregt-evaluationgtfilter-and-outlier-elimination/ Share on other sites More sharing options...
[Ja...] Posted May 23, 2023 Share Posted May 23, 2023 Under resources save/load defaults, you can set the default evaluations to what you want. They will be applied to the feature within the characteristic. The evaluation doesn't need to be applied to the feature before the characteristic. If that is what you want though you could use resources- Filter- Geometry- Filter, to set them all at the same time. Link to comment https://qualityforum.zeiss.com/topic/7888-featuregt-evaluationgtfilter-and-outlier-elimination/#findComment-34238 Share on other sites More sharing options...
[Sc...] Posted May 23, 2023 Author Share Posted May 23, 2023 I don' t see Filter- Geometry- Filter under menu Resources Screen shot attached is from Calypso 2018. Under resources save/load defaults>filter/outlier(screen shot attached) have been set however I don't see the filters was not checked withing features.Screenshot 2023-05-23 082121.pngScreenshot 2023-05-23 081456.png Link to comment https://qualityforum.zeiss.com/topic/7888-featuregt-evaluationgtfilter-and-outlier-elimination/#findComment-34240 Share on other sites More sharing options...
[Ri...] Posted May 23, 2023 Share Posted May 23, 2023 Please sign in to view this quote. It only applies the default filters/outlier inside the Characteristic. From the Features tab, it will remain un-filtered. Link to comment https://qualityforum.zeiss.com/topic/7888-featuregt-evaluationgtfilter-and-outlier-elimination/#findComment-34242 Share on other sites More sharing options...
