[St...] Posted May 17, 2023 Share Posted May 17, 2023 Looking for some help. I am using an RDS-CAA with VAST XXT, and in one direction the probe is not square to my machine. A+90 seems to be the problem. Any recommendations on how to fix this? Thanks A+90, B-90 = Not square A+90, B+90 = Not square A-90, B+90 = Square A-90, B-90 = SquareCMM Probe.jpg Link to comment https://qualityforum.zeiss.com/topic/7916-rds-caa-not-square-to-machine-in-one-angle/ Share on other sites More sharing options...
[Da...] Posted May 17, 2023 Share Posted May 17, 2023 How did you square up the 1,2,3 block? Link to comment https://qualityforum.zeiss.com/topic/7916-rds-caa-not-square-to-machine-in-one-angle/#findComment-34410 Share on other sites More sharing options...
[St...] Posted May 17, 2023 Author Share Posted May 17, 2023 Yes, the 1,2,3 block is square to the machine. The first picture was in A +90, B-90. This next picture i am uploading is in A-90, B +90. both probing in the same machine angel, but one is out of square the other is square. Not sure how to fix it.CMM Probe 1.0.jpg Link to comment https://qualityforum.zeiss.com/topic/7916-rds-caa-not-square-to-machine-in-one-angle/#findComment-34412 Share on other sites More sharing options...
[Ri...] Posted May 18, 2023 Share Posted May 18, 2023 Please sign in to view this quote. As long as the 18-pin probe adapter is seated correctly, there isn't anything that you can do short of calling hardware support. Link to comment https://qualityforum.zeiss.com/topic/7916-rds-caa-not-square-to-machine-in-one-angle/#findComment-34414 Share on other sites More sharing options...
[To...] Posted May 19, 2023 Share Posted May 19, 2023 I had something similar to this this happen once when the RDS was replaced. Apparently, the CAA mapping needed to be re-loaded. Zeiss did it remotely. Link to comment https://qualityforum.zeiss.com/topic/7916-rds-caa-not-square-to-machine-in-one-angle/#findComment-34416 Share on other sites More sharing options...
