Hello Jake,
you could construct a touch circle: https://techguide.gom.com/en/article/cmd_primitive_create_touch_circle.html
It needs an existing circle, which is then moved along a specified direction until it the section. You could create the first circle in relation to the vertical line and use the line as the touch direction.
Regards,
Nanno
https://qualityforum.zeiss.com/topic/793-circle-tangent-2-lines/#findComment-2427
