Start Measurement User Information
Inspection_pre_start_dialog.bat
Or if you have a PCM license - inspection_pre_start_dialog_pcm.txt
You could also use inspection_start.bat or inspection_start_pcm.txt as they execute when the "Start" button is pressed, however, the program will commence unless you put a proper wait command in the syntax
