[Sa...] Posted April 25, 2023 Share Posted April 25, 2023 I am new to Gear Pro and need some help. I have run a gear and it produced a report, but I need to adjust the scale on it so it isn't just showing 1 or 0 for my results on each tooth. I believe it is showing in thousandths and not tenths. I have attached a screen shot that shows the red circled areas that I am needing to change. Any help would be greatly appreciated. Screenshot 2023-04-25 150406.pngFetching info... Link to comment Share on other sites More sharing options...
[Ch...] Posted April 25, 2023 Share Posted April 25, 2023 Sarah, Welcome. Please try this .. you are correct output for reports are as follows 0.001235" will equal 1.235" on report. Link to comment Share on other sites More sharing options...
[Sa...] Posted April 26, 2023 Author Share Posted April 26, 2023 I have made those changes. If I re-run my saved data, should it update the report or will I have to do a new run of the part to get the updated numbers? Link to comment Share on other sites More sharing options...
[Ch...] Posted April 26, 2023 Share Posted April 26, 2023 not sure how recalling the .act data will behave, worst case you may have to do this for every recall file.. Link to comment Share on other sites More sharing options...
[Ed...] Posted April 28, 2023 Share Posted April 28, 2023 Hi, If you will update your program than all next made measurements will be updated, but .act files won`t. If you want to update some of previous measurements you will need to open every .act file and update in the same way as proper program 🙂 Link to comment Share on other sites More sharing options...
