Measuring tool?
Hello Friends!
Total Calypso newbie here so sorry if I'm asking a dumb question.
Does calypso have a measure tool similar to the one in PC_DMIS? Like I'm trying to figure out a retract distance so I don't collide with a boss coming out of a cylinder and I just would like to measure the distance between the boss and the face behind it. I know I could extract the features and do the math manually, but PCDMIS had a really nifty measure function that would let me click two faces and quickly get the distance between them. Anything like that here?
Thanks in advance!
https://qualityforum.zeiss.com/topic/8104-measuring-tool/
It is pretty easy to extract both features and do a distance measurement between them.. how close are these features to one another? I generally just use a little mental math on clearance and retract distances that I don't make standard. If you need help estimating distances, grab a pair of digital calipers and open them up to 0.010", 0.020" etc to get a good eye ball on what each one looks like.
https://qualityforum.zeiss.com/topic/8104-measuring-tool/#findComment-35428
So, yeah, Conner to answer your question... no. Unfortunately, there isn't a nifty tool in Calypso like you described. I know what tool you're referencing. Solidworks has something similar called the tape measure. As others have mentioned, it's fairly simple to extract nominal distances in Calypso, but it's usually done through a distance characteristic. Not quite as point and shooty.
https://qualityforum.zeiss.com/topic/8104-measuring-tool/#findComment-35432
