[Jo...] Posted March 29, 2023 Share Posted March 29, 2023 Hello, Is there a check box anywhere to turn on/off the little timer that comes up when you run a program? Thanks! Link to comment Share on other sites More sharing options...
[DW...] Posted March 29, 2023 Share Posted March 29, 2023 Do you mean the Calypso Monitor that pops up when you start Calypso for the first time? Click the settings icon in the Calypso Monitor window (looks like a gear) in the upper right and uncheck everything. Close the window, and the Calypso Monitor window should not come back while that instance of Calypso is open. Link to comment Share on other sites More sharing options...
[Ju...] Posted March 29, 2023 Share Posted March 29, 2023 I usually just keep mine checked to not record the time, unless I know I'm going to be running the full program. Then, I re-check the box afterward, so it has an accurate runtime. Link to comment Share on other sites More sharing options...
[Jo...] Posted March 29, 2023 Author Share Posted March 29, 2023 Please sign in to view this quote. I restarted Calypso and it came back up. When you check the "do not record" it must cancel it from coming up on subsequent runs. I didn't see if Calypso Monitor was available to open in one of the main drop downs. Link to comment Share on other sites More sharing options...
[Dy...] Posted March 31, 2023 Share Posted March 31, 2023 You can re open it without having to reset the software by going to this file path and opening the application againMonitor.PNG 1 Link to comment Share on other sites More sharing options...
