Remeasure Loop
Hello!
Trying to set up (below) a feature to be remeasured if it doesn't achieve a certain form error (.0005 in this case) I want it to remeasure a max of 3x. What goes into the [LoopIndex]? Don't usually do much in parameter postsettings and PCM, but I'm trying!
Thanks!
i=.0005
if getActual("Sphere2").form >i then
measure("Sphere2"[,LoopIndex])
endif
https://qualityforum.zeiss.com/topic/8272-remeasure-loop/
  • 2 months later...
Hello,
I have a similar problem. I created a circle using a pattern (with LOOP-index LOOP2). So I have 8 circles overall.
But when I check the form either in the pre-settings of the radius-characteristic by
for i=1 to 8
  if getActual("Kreis",i).form > 0.008 then
     measure("Kreis",i)
       endif
          next i
or in the post-settings of the feature by
if getActual("Kreis",LOOP2).form > 0.008 then
   measure("Kreis",LOOP2)
       endif
the relevant feature won't be remeasured although I know the circle[4] doesn't fulfil the condition.
Even if I put the command
measure("Kreis",4)
in pre-settings of the radius-characteristic won't repeat the measurement.
Does anybody know the reason?
https://qualityforum.zeiss.com/topic/8272-remeasure-loop/#findComment-36318
