[Ro...] Posted December 16, 2021 Share Posted December 16, 2021 I think i would benefit from a basic class again, i think that i could relearn a lot of the super simple things that i have forgot over the years, or never really used at the time. Anyhow...... is there a quick way to rename a group of features? Like for instance i have a program where i have 15 holes with a counterbore, so in this instance i need to take the 15 thru holes, rename the 15 thru holes, then take the 15 counterbore holes and rename the 15 counterbores. I would like to in 1 motion rename Circle1 thru Circle15 to 150 Circle1 thru 150 Circle 15, then Counterbore Circle1 thru Counterbore Circle15dfsdfsdfsdgf.PNG Link to comment https://qualityforum.zeiss.com/topic/8316-i-really-need-to-go-back-and-take-basic-class-again/ Share on other sites More sharing options...
[Ri...] Posted December 16, 2021 Share Posted December 16, 2021 Select them all - Edit - Replace - Find Circle - Replace with Ø6.5mm - Circle - That is kind of my naming strategy. Link to comment https://qualityforum.zeiss.com/topic/8316-i-really-need-to-go-back-and-take-basic-class-again/#findComment-36628 Share on other sites More sharing options...
[Ma...] Posted December 16, 2021 Share Posted December 16, 2021 Hi You can replace names if you press Ctrl + H, it will replace only 1 feature or all features see attached. I hope this will help.Replace.jpg Link to comment https://qualityforum.zeiss.com/topic/8316-i-really-need-to-go-back-and-take-basic-class-again/#findComment-36630 Share on other sites More sharing options...
[Ro...] Posted December 16, 2021 Author Share Posted December 16, 2021 Boom!!! That's it! Link to comment https://qualityforum.zeiss.com/topic/8316-i-really-need-to-go-back-and-take-basic-class-again/#findComment-36632 Share on other sites More sharing options...
[Ri...] Posted December 16, 2021 Share Posted December 16, 2021 A tip. If you select the group of features while in the menu, it will only search and replace within that selection. 🙂 Link to comment https://qualityforum.zeiss.com/topic/8316-i-really-need-to-go-back-and-take-basic-class-again/#findComment-36634 Share on other sites More sharing options...
[Ri...] Posted December 16, 2021 Share Posted December 16, 2021 Oh - and this is not taught in any class as far as I am aware. Link to comment https://qualityforum.zeiss.com/topic/8316-i-really-need-to-go-back-and-take-basic-class-again/#findComment-36636 Share on other sites More sharing options...
[Se...] Posted December 16, 2021 Share Posted December 16, 2021 Please sign in to view this quote. You´re right! It was the same for me when I learned about the use of the "F5" key! Sure you all know about it 😉 Link to comment https://qualityforum.zeiss.com/topic/8316-i-really-need-to-go-back-and-take-basic-class-again/#findComment-36638 Share on other sites More sharing options...
[Ro...] Posted December 16, 2021 Author Share Posted December 16, 2021 Please sign in to view this quote. I feel like this is the kind of trap that i would set...... Kinda like back in the old days, when the internet was mainly a bunch of forums and rooms i would tell people that Ctrl+W would fix whatever problem they were having, but it really just closed the current tab, and a couple seconds later i would see "Sebastien has left the room". Link to comment https://qualityforum.zeiss.com/topic/8316-i-really-need-to-go-back-and-take-basic-class-again/#findComment-36640 Share on other sites More sharing options...
[Ri...] Posted December 16, 2021 Share Posted December 16, 2021 How many of you run from the joystick via the f8 button? 🙂 Lifesaver for the big machines. Link to comment https://qualityforum.zeiss.com/topic/8316-i-really-need-to-go-back-and-take-basic-class-again/#findComment-36642 Share on other sites More sharing options...
[Cr...] Posted December 16, 2021 Share Posted December 16, 2021 Just yesterday I found this and started to play around with. Extras-Settings-Environment-Default Name. Check "Activate Name Allocation", open the folder, Open the text file "NamePatternsDefault" and within that file you can change the naming of features you pick. I had to mess around with it for a while to finally get it to output how I wantedScreenshot 2021-12-16 102019.pngScreenshot 2021-12-16 101325.png Link to comment https://qualityforum.zeiss.com/topic/8316-i-really-need-to-go-back-and-take-basic-class-again/#findComment-36644 Share on other sites More sharing options...
[Je...] Posted December 16, 2021 Share Posted December 16, 2021 . Impressive. Now the real question: How many of you know how to unlock the hidden Tetris game in Calypso? . . Jeff Frodermann Meier Tool & Engineering Anoka, Minnesota. Link to comment https://qualityforum.zeiss.com/topic/8316-i-really-need-to-go-back-and-take-basic-class-again/#findComment-36646 Share on other sites More sharing options...
[Ph...] Posted December 17, 2021 Share Posted December 17, 2021 Please sign in to view this quote. I could tell you how to do it, but the last time I opened my mouth "Uncle Carl" deactivated my account.. 😃 Send me a PM if you must know!! Link to comment https://qualityforum.zeiss.com/topic/8316-i-really-need-to-go-back-and-take-basic-class-again/#findComment-36648 Share on other sites More sharing options...
[No...] Posted December 17, 2021 Share Posted December 17, 2021 Please sign in to view this quote. I always asked myself if there is a hidden key combination or something to start it. I know how to do it "the other way", but I find that too cumbersome. Link to comment https://qualityforum.zeiss.com/topic/8316-i-really-need-to-go-back-and-take-basic-class-again/#findComment-36650 Share on other sites More sharing options...
[Ph...] Posted December 17, 2021 Share Posted December 17, 2021 Please sign in to view this quote. Add it to the "Special Menu", then it's only one click away... 😎 Link to comment https://qualityforum.zeiss.com/topic/8316-i-really-need-to-go-back-and-take-basic-class-again/#findComment-36652 Share on other sites More sharing options...
[Is...] Posted December 17, 2021 Share Posted December 17, 2021 ... Link to comment https://qualityforum.zeiss.com/topic/8316-i-really-need-to-go-back-and-take-basic-class-again/#findComment-36654 Share on other sites More sharing options...
[Ra...] Posted December 19, 2021 Share Posted December 19, 2021 You need to go back to school. You should probably be teaching it. Link to comment https://qualityforum.zeiss.com/topic/8316-i-really-need-to-go-back-and-take-basic-class-again/#findComment-36656 Share on other sites More sharing options...
[Ch...] Posted December 20, 2021 Share Posted December 20, 2021 wattonchad3@gmail.com Just incase anyone wants to drop me some Tetris instructions. Just saying. Link to comment https://qualityforum.zeiss.com/topic/8316-i-really-need-to-go-back-and-take-basic-class-again/#findComment-36658 Share on other sites More sharing options...
[Ph...] Posted December 20, 2021 Share Posted December 20, 2021 Please sign in to view this quote. PM sent.... Link to comment https://qualityforum.zeiss.com/topic/8316-i-really-need-to-go-back-and-take-basic-class-again/#findComment-36660 Share on other sites More sharing options...
[Ow...] Posted December 20, 2021 Share Posted December 20, 2021 I would like to take it over 15 years later just to see if they put such an emphasis on programing and running from the characteristics side. The instructor back then was adamant about programming from the characteristic side and his instruction itinerary/manual was some-what written to teach it that way and I might add with several bad German to English translations. We all think differently and maybe some adapt quicker but, coming from learning to program using syntax style programming focusing on features and stylus use, it was challenging and I ended up programming and running from the features side anyway, like most do. It was like telling me to plan a vacation around the world while prioritizing which places I wanted to see most regardless of cost and how I might get there. Three months later taking the advance and PCM class, the instructor was like, oh forget all of that. 🙄 That aside, The hidden game is definitely Frogger on my end. Link to comment https://qualityforum.zeiss.com/topic/8316-i-really-need-to-go-back-and-take-basic-class-again/#findComment-36662 Share on other sites More sharing options...
[Ro...] Posted December 21, 2021 Author Share Posted December 21, 2021 Please sign in to view this quote. I went in for an interview a couple months ago before taking the job that i'm currently at, they decided to pass. Link to comment https://qualityforum.zeiss.com/topic/8316-i-really-need-to-go-back-and-take-basic-class-again/#findComment-36664 Share on other sites More sharing options...
[Ün...] Posted December 22, 2021 Share Posted December 22, 2021 Please sign in to view this quote. unalkirat@gmail.com if possible i would like Link to comment https://qualityforum.zeiss.com/topic/8316-i-really-need-to-go-back-and-take-basic-class-again/#findComment-36666 Share on other sites More sharing options...
[Je...] Posted December 22, 2021 Share Posted December 22, 2021 Please sign in to view this quote. Definitely their loss. I've been learning from you on this forum for years. You've got serious skills, and I'd hire you in a heartbeat. Jeff Frodermann Meier Tool & Engineering Anoka, Minnesota . Link to comment https://qualityforum.zeiss.com/topic/8316-i-really-need-to-go-back-and-take-basic-class-again/#findComment-36668 Share on other sites More sharing options...
[Jo...] Posted December 22, 2021 Share Posted December 22, 2021 I wouldn't mind checking out this hidden Tetris! Hook me up! 😃 Link to comment https://qualityforum.zeiss.com/topic/8316-i-really-need-to-go-back-and-take-basic-class-again/#findComment-36670 Share on other sites More sharing options...
[Wo...] Posted December 22, 2021 Share Posted December 22, 2021 Please sign in to view this quote. OMG thank you! The search jumping back to previous groups was driving me nuts! Link to comment https://qualityforum.zeiss.com/topic/8316-i-really-need-to-go-back-and-take-basic-class-again/#findComment-36672 Share on other sites More sharing options...
[Mi...] Posted March 8, 2023 Share Posted March 8, 2023 Please sign in to view this quote. I'm curious! How can I access this hidden Tetris game? 🙂 Link to comment https://qualityforum.zeiss.com/topic/8316-i-really-need-to-go-back-and-take-basic-class-again/#findComment-36674 Share on other sites More sharing options...
