automatic re-measurement of a characteristic
I created a command line to be able to repeat a feature if out of tolerance. below: if getActual("_D_").form>=0.001 and i<2 then i=i+1
measure("_D_").form
else
endif
can it be improved?
is there any other way?
I don't have PCM but you could loop the characteristic. This doesn't feel like much of an improvement, more like, here is another way to do the same thing.
Looping does not work, I've tried to loop Characteristics in version 2021 and 2022 with or without a break condition the software runs it once and spits out 3 of the same results without remeasuring. I spent around 1 to 2 hours with zeiss support trying to figure a work around to auto remeasure.
I've been playing around trying to find a solution...kind of sucks that Loop doesn't work correctly.
Sorry mate seems like you have the best solution for now.
