[To...] Posted March 13, 2023 Share Posted March 13, 2023 Any ideas on how I would setup this alignment for the true position callout on this view? Datum A and D are both planes on the bottom of the part. I don't remember ever seeing this kind of datum setup before.Capture.JPG Link to comment Share on other sites More sharing options...
[SH...] Posted March 14, 2023 Share Posted March 14, 2023 Datum A and D already constrained the 5 degree of freedom and datum B constrain translation along y axis, but what datum C is doing here?? If datum B is a feature of size you can use MMB, but you have to use geometry best fit alignment for A and D. So using MMB on datum B is might be a hard nut to crack... 😭 Link to comment Share on other sites More sharing options...
[Ma...] Posted March 14, 2023 Share Posted March 14, 2023 Please sign in to view this quote. How you implement A-D? Link to comment Share on other sites More sharing options...
[Da...] Posted March 14, 2023 Share Posted March 14, 2023 Please sign in to view this quote. Looks like Freeform is a must here to make |A-D| Link to comment Share on other sites More sharing options...
[Me...] Posted March 14, 2023 Share Posted March 14, 2023 I may be wrong (not much experience yet), but could you check Position using RPS Alignment (Using points against A-D's surface as datum pts)? For those without Curve/Freeform. Link to comment Share on other sites More sharing options...
[SH...] Posted March 14, 2023 Share Posted March 14, 2023 Please sign in to view this quote. In my knowledge, this is not a scenario of RPS alignment.. Curve and freeform surface are not must for this puzzle. I would go with GBFA... Link to comment Share on other sites More sharing options...
[Er...] Posted March 16, 2023 Share Posted March 16, 2023 Datum D is a "secondary loading plane" which implies datum A is the primary. I would try... Spatial-A Planar-D XYZ are going to be datums ABC according to the setup. Link to comment Share on other sites More sharing options...
