[Me...] Posted March 3, 2023 Share Posted March 3, 2023 Hello everyone, we have many programs and they all run fine with proper loading of CAD model (*.SAT) in CALYPSO 2021, but when I load the same program from same destination with CALYPSO 2022 he does not load the model, no error, nothing, Program is loaded, everything works, but no model... When I check CAD - Modify CAD entities - hierarchy there is no model. It is anoying 🙁 . Thank you very much in advance for any tip how to solve this issue Link to comment https://qualityforum.zeiss.com/topic/8406-cylypso-2022-does-not-load-models/ Share on other sites More sharing options...
[No...] Posted March 3, 2023 Share Posted March 3, 2023 Check File / Load Settings: Link to comment https://qualityforum.zeiss.com/topic/8406-cylypso-2022-does-not-load-models/#findComment-37138 Share on other sites More sharing options...
[Me...] Posted March 3, 2023 Author Share Posted March 3, 2023 Please sign in to view this quote. Thank you Norbert, unfortunately it does not help. Link to comment https://qualityforum.zeiss.com/topic/8406-cylypso-2022-does-not-load-models/#findComment-37140 Share on other sites More sharing options...
[No...] Posted March 3, 2023 Share Posted March 3, 2023 Is the model located in the measurement plan folder? (model.sab) Link to comment https://qualityforum.zeiss.com/topic/8406-cylypso-2022-does-not-load-models/#findComment-37142 Share on other sites More sharing options...
[Me...] Posted March 3, 2023 Author Share Posted March 3, 2023 Please sign in to view this quote. YES Link to comment https://qualityforum.zeiss.com/topic/8406-cylypso-2022-does-not-load-models/#findComment-37144 Share on other sites More sharing options...
[Me...] Posted March 9, 2023 Author Share Posted March 9, 2023 SOLVED, when I rename folder with certain program for example from *Endprüfung* to *Endpruefung* model is loaded. The problem simply was all these special german characters... Link to comment https://qualityforum.zeiss.com/topic/8406-cylypso-2022-does-not-load-models/#findComment-37146 Share on other sites More sharing options...
[Da...] Posted March 9, 2023 Share Posted March 9, 2023 Carl Z., when importing CAD, a window with error "remove special characters" would be really handy. Link to comment https://qualityforum.zeiss.com/topic/8406-cylypso-2022-does-not-load-models/#findComment-37148 Share on other sites More sharing options...
[Mi...] Posted March 10, 2023 Share Posted March 10, 2023 i had same problem with special characters like ˇ and ´. Solution is set windows preferences Control panel - Region - tab Administrative - Change region setings - select Beta: Use unicode UTF-8 Link to comment https://qualityforum.zeiss.com/topic/8406-cylypso-2022-does-not-load-models/#findComment-37150 Share on other sites More sharing options...
