[Ra...] Posted February 17, 2023 Share Posted February 17, 2023 Im having a issue where my probe wants to crash against the part even though i have added big enough of a clearance Plane. Its a very tight spot. Is there a place in the clearance data you make the probe , take a the full motion out and then in. Link to comment Share on other sites More sharing options...
[Mi...] Posted February 17, 2023 Share Posted February 17, 2023 You likely need to adjust or zero the clearance distance for that feature( I set to 0 by default and only change it where it's needed) Adjust your retract distance for that feature. Or put in "Position without probing" in the strategy Link to comment Share on other sites More sharing options...
[Ju...] Posted February 17, 2023 Share Posted February 17, 2023 I also use CMM position points when measuring features in hard-to-reach spots. Link to comment Share on other sites More sharing options...
[Co...] Posted February 24, 2023 Share Posted February 24, 2023 Please sign in to view this quote. CMM Positions definitely are your friend. Just be careful with them if you aren't used to using them, but this is what I would use also. Link to comment Share on other sites More sharing options...
